Hey guys, i can't seem to get a simple thing to work in this small formular.. Its not so clear what the priority.getName() field returns. I have entered this enter a text custom field and just returned priority.getName() and it comes back as "Medium" however wheni try a Number custom field i can't seem to break into the if statement:
<!-- @@Formula: priorityField = issue.get("priority"); if (priorityField.getName() == "Medium") return 50; -->
The above code doesn't return any errors. However it doesn't return anything, simply because the if statement isn't being entered into. I have tested my if statement by making (priorityField.getName() == priorityField.getName()) and it works perfectly fine..
Are Priorities are labeled, medium/low/high/Critical.
Any ideas?
