Custom field Javascript migration from Jira 4.4 to 5.1
MIKE VEILLEUX July 22, 2012
Currently using Jira 4.4, we have a custom field than is populating 2 other fields using onchange.
We plan to upgrade to Jira 5.1, but the javascript isn't working anymore as Jira5 doc mentions, which is a lillte sad...
Anyway, would anyone be kind enough to help me (and probably many other users) make the following code work in Jira 5.1.
<script type="text/javascript">
            function generateURL() {
                var sel = document.getElementById('customfield_10023');
                var selText = sel.options[sel.selectedIndex].text;
                var Fieldtoreadonly = document.getElementById("customfield_10023");
                selText = selText.substr(selText.lastIndexOf('(') + 1);
                selText = selText.substr(0, selText.indexOf(')'));
                document.getElementById('customfield_10761').value = 'http://intranet/wiki/index.php/' + selText ;
switch (selText) {
case '4464': document.getElementById('customfield_10763').value = 'Aviser direction si support pour emballeuse (interface)' ;
break;
case '4564': document.getElementById('customfield_10763').value = 'Aviser direction si support pour emballeuse (interface)' ;
break;
case '4470': document.getElementById('customfield_10763').value = 'Aviser direction si support pour emballeuse (interface)' ;
break;
case '4467': document.getElementById('customfield_10763').value = 'Aviser direction si support pour emballeuse (interface)' ;
break;
default:document.getElementById('customfield_10763').value = '';
break;
            window.onload = function() {
                document.getElementById('customfield_10023').onchange = generateURL;
        </script>
In advance, thank you!
RambanamP
September 4, 2012
The Best way to use Javascript in jira is by using webresource, check the following post
https://answers.atlassian.com/questions/47843/strange-javascript-problem-in-create-screen
John Burns
September 3, 2012
This is how i did it:
(function($) {
    AJS.toInit(function(){
		//function
    JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e, context) {
		//function
})(AJS.$);
 </script>
Harry Chan
September 4, 2012
I got it working this way too.
JoeR
Have same issue, want to be able to have javascript fire for creates and edits. But trying to understand this code...would })(AJS.$); in John's code example be the following to work for Mike's issue?
})(AJS.$('#customfield_10023').live("change",generateURL));
or ?
RambanamP
August 27, 2013
you have to bind your code in NEW_CONTENT_ADDED event
JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e,context) {
alert("Hello!!!");
i have given link in my answer!!
MIKE VEILLEUX August 30, 2012
thanks for the suggestion, and sorry for the delay, it's vacation season!!
But i'm a little lost, would someone be kind enough to have the code in first post adapted to work with the jquery .live method?
in advance, thank you
Florin Manaila
September 2, 2012
becomes
window.onload = function(){
    AJS.$('#customfield_10023').live("change",generateURL);
MIKE VEILLEUX September 3, 2012
Florin, Thanks for the reply,
The code works, but only if I open the form in a new window still, the create/edit popup doesn't call the code, still the same situation...
regards
Florin Manaila
July 24, 2012
You could use the .live() method from jQuery (AJS).
http://api.jquery.com/live/
Florin Manaila
July 24, 2012
Dieter
July 22, 2012
I tried that but it does not work when creating/updating the issue from the "popup"
If I open the edit window in a new tab, then it works as expected...
