Custom field count/info
Ron Jacob
Is there any JQL query or other  way to to export the list of custom field in jira instance
Radhika Shinde February 23, 2022
If you do export all fields that will provide you information on all fields that are there in Jira
Nic Brough -Adaptavist-
February 28, 2018
Easiest way is to go to Admin -> Custom fields and simply scrape the list from there.
Ron Jacob
Its a very big list; wanted to see if I can export o excel somehow ?
February 23, 2022
It shouldn't be a long list, that's why there's no simple "export list" function.
You might want to take a look at the housekeeping and migration prep apps you can get - some of them make the list more manageable in the UI and a couple provide exports.
