Hi all,
my need is to create a custom field to save an address geo referetiated.
I'm using JSU - Suite Utilities for Jira and it is really great but it seems one feature is missing.
It is possible to create a free text field where to write an address that is showed, after ticket creation/update as a point on a google map, but the autocomplete feature is missing, so there is no way to understand if google will be able to show the point on the map, another missing feature is that is not possible to change the position on the map and to reflect the result on the text field, is there anyone that solved in another way?
Thanks in advance
Giacomo
Hi @Giacomo Esposito please have a look at Fancy Fields for Jira, I believe it does what you are looking for.
hi Giacomo
in the latest version of JSU you can create a custom text field called "text location", this is a integration with google, perhaps, if you define the installation type, i can find other options to that.
The custom field only can be use in DataCenter or Server installation, in cloud don`t have any alternative for this requierement.
If you know a solution for cloud, let me know
Read the story
