Custom field insertion in e-mail subject (GStringTemplate)
Nabil Sayegh
January 14, 2013
I'm trying to send a mail via a transition's post-function.
The subject and body fields say, you can enter GStringTemplates, but I can't find any decent documentation about that.
How do I simply insert e.g. custom field foo (id 12345) to the subject and/or body?
JamieA
January 14, 2013
http://groovy.codehaus.org/api/groovy/text/GStringTemplateEngine.html
It's a pain doing it in the subject. You need something like this:
Issue ID: ${issue.id}, Custom Field Value: <% out << issue.getCustomFieldValue(componentManager.getCustomFieldManager().getCustomFieldObjectByName("My custom field")) %>
Nabil Sayegh
January 14, 2013
Thank you.
I'll try that, but before that I have to configure a test smtp.
JamieA
January 14, 2013
You can use the "preview" function to see what the subject will look like. This is highly recommended before firing off emails.
Nabil Sayegh
January 14, 2013
Interesting. Where can I see the preview?
I can configure the field "Preview Issue Key" when editing the transition, but I don't see no button "Preview".
Nabil Sayegh
January 14, 2013
I tried with this as subject:
"Es wurde ein neues Artefakt $issue zum Deployment gemeldet. cfValues['customfield_12714']".
But it doesn't resolve the custom field and results in this subject:
"[TEST] Es wurde ein neues Artefakt LUUS-1126 zum Deployment gemeldet. cfValues['customfield_12714']"
JamieA
January 14, 2013
Answer updated...
Nabil Sayegh
January 15, 2013
Thanks for the update. But I fear, it's still not working:
<% out << issue.getCustomFieldValue(componentManager.getCustomFieldManager().getCustomFieldObjectByName("customfield_12714")) %>
2013-01-16 08:33:47,003 http-8081-17 ERROR nabil.sayegh@example.com 513x22538x1 1o7xo1j 10.109.54.241,127.0.0.1 /secure/WorkflowUIDispatcher.jspa [onresolve.jira.groovy.GroovyFunctionPlugin] Error executing post-function
java.lang.NullPointerException
	at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:938)
	at com.atlassian.jira.issue.Issue$getCustomFieldValue.call(Unknown Source)
	at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
	at groovy.tmp.templates.GStringTemplateScript6$_getTemplate_closure1.doCall(GStringTemplateScript6.groovy:2)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90)
	at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233)
	at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:272)
	at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:884)
	at groovy.lang.Closure.call(Closure.java:412)
	at groovy.lang.Closure$WritableClosure.writeTo(Closure.java:828)
	at groovy.lang.Closure$WritableClosure.toString(Closure.java:954)
Nabil Sayegh
January 15, 2013
I also tried with :
<% out << issue.getCustomFieldValue(componentManager.getCustomFieldManager().getCustomFieldObjectById(12714)) %>
and
<% out << issue.getCustomFieldValue(componentManager.getCustomFieldManager().getCustomFieldObjectById(12714L)) %>
But am getting these errors:
2013-01-16 08:51:51,617 http-8081-22 ERROR nabil.sayegh@example.com 531x22643x1 j2tplz 10.109.54.241,127.0.0.1 /secure/WorkflowUIDispatcher.jspa [onresolve.jira.groovy.GroovyFunctionPlugin] Error executing post-function
groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.managers.DefaultCustomFieldManager.getCustomFieldObjectById() is applicable for argument types: (java.lang.Long) values: [12714]
Possible solutions: getCustomFieldObject(java.lang.Long), getCustomFieldObjects(), getCustomFieldObject(java.lang.String), getCustomFieldObjectByName(java.lang.String), getCustomFieldObjects(com.atlassian.jira.issue.Issue), getCustomFieldObjects(com.atlassian.jira.issue.search.SearchContext)
JamieA
January 15, 2013
You need the name of the custom field, not the ID. The name is the name that you see when editing an issue in the UI. If you want to use the ID, change getCustomFieldObjectByName to another method.
Nabil Sayegh
January 15, 2013
Works!
Thank you.
BTW: I tried getCustomFieldObjectById() but it didn't work because it expects a java Long. Do you know how to specify that in Groovy? I tried without quotes and with and without L.
JamieA
January 15, 2013
Use either `1 as Long` or `1L`, or `new Long(1)`, no quotes in either case.
guis March 20, 2013
I use the plugin script runner and use the script post-function. I use the script "Sending a custom email on a transition'. How insert the value of the custom field present in the issue in the template of the mail? How recove the value by id?
Guis
JamieA
March 21, 2013
Isn't this question the same as the one you are asking? Why do you need the custom field ID? If you need it you can get it from the view custom fields page, or from the db.
guis March 21, 2013
Thank you. How I can to recove the name of status by groovy? I tried issue.status?.name but it doesn't work.
Guis
JamieA
March 21, 2013
can you explain doesn't work. That should work but issue.statusObject.name is probably better.
guis March 21, 2013
Thank you for the answer. I forget "$".
Rocky July 23, 2014
HI jaime,
Currently we are using jira 6.0.5
we need to display the custom field value in the subject of the email whenever the respective field is updated
the field is a version picker
currently we are using the text mode for email notification.i have edited the issueupdated.vm.i have tried the below template
# if the custom field value is empty print the issuekey.issuetype,and summary else print issuekey,updated custom field value and issue summary
if($issue.getCustomFieldValue("customfield_1001") = "")
($issue.key) ($issue.issueTypeObject.name) $issue.summary
#else
($issue.key) $issue.getCustomFieldValue("customfield_1001") ($issue.issueTypeObject.name) $issue.summary
#end
im not getting the value when the custom field is updated.
please help me with valid template
JamieA
July 24, 2014
that's a velocity template, not related to my plugin
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
