×We have a sql db table that has the values I would like to display in a Test Management for Jira custom field. I can't seem to find the documentation to point me in the right direction.
Any suggestions
HI. You need to install plugins and use them.
https://marketplace.atlassian.com/apps/23337/elements-connect-formerly-nfeed?hosting=server&tab=overview
or
https://marketplace.atlassian.com/apps/1210749/power-custom-fields?hosting=datacenter&tab=overview
or other
Is the only way to have a custom field that connects to a data source is via a plugin? I thought Atlassian might have something out of the box that you drop a control and then you define the sql to gather a list of strings.
