Sign up Log in
Custom field to display text and be non editable in the create screen
Krithica Gowri Shankar
I need to display a default text using custom field in the create screen.
Message field will work. But i would like to know are there any other ways to achieve this without using any plugins?
Krithica
Alexey Matveev
November 6, 2018
If you are on Cloud, you can use the Message Custom Field.
If you are on Server, you can not achieve it without a plugin.
I am using jira server. Can you please tell me about the plugins other than Jira tool kit and scriptrunner behaviours  to achieve this?
Alexey Matveev
November 6, 2018
Why you do not want to use the Toolkit Plugin for Jira plugin? It is a free add-on.
Like Grigory Salnikov likes this
To try and analyse various options of plugins. I wanted to try if it is possible with some other plugins or methods as well.
Alexey Matveev
November 6, 2018
Thank you
