Hello, I am new with Jira. How many custom fields do you currently use in Jira? Do custom fields influence the performance of Jira? Best regards Sven
Hi Sven,
There could be a potential impact on the performace, however custom fields alone should not reduce it like in case of number of issues.
If you want to check different behaviors you can try to set up your own JIRA instance and use a plugin called JIRA Data Generator that will let you create as many custom fields and issues that you will want. Then the only this is left to do is to check if after that there is an impact to the performance.
I hope that will help.
Best Regads,
Mirek
Hi Sven,
1427 tickets is not an issue if having that kind of configuration.. Having 400k an more could be a problem, so you still have time to increase to that number.
If you would like to read about some performance test yoube this documentation could be helpfull:
https://confluence.atlassian.com/pages/viewpage.action?pageId=312740794
This is for JIRA 4 but is giving more overview about the difference between few configurations.
I hope that will help,
Best Regards,
Mirek
Hi, You can get the relevant info from
