Hi All,
I am trying to fetch custom field from plugin by using :
customFieldManager.getCustomFieldObjectsByName(FIELD_NAME);
Sometime it is able to fetch the custom field object but sometime it is not able to fetch the object.
When It is not able to fetch the object, then I have to disable and enable the plugin and it will start to work.
Can anyone let me know what can be the permanent solution to it.
Chandramouli
