Customer quoting add-on?
Dennis_H
Is there something that will allow us to create product quotes for customers? I'd like it to be able to have item lists to create quotes from and I could tie it to a project.
Angélica Luz
December 12, 2018
Hi Dennis,
I haven't found an add-on to create quotes specifically, but there is an add-on that allows the creation of forms that may help you.
The add-on is ProForma Lite: Forms & Custom Fields that allow you to create forms and it's not necessary to create custom fields on Jira.
This is the free version that allows you to create three forms.
Hope this helps!
Angélica
