Customfield Javascript not working on project Change. Any idea why?
Eman Cauchi September 29, 2017
We have added some JavaScript in our customfields specific to a project and when the project is changed from something else to this particular project and therefore the issue and screen change the JavaScript is not loaded.What can I do to make it load on project change?
Andy Heinzer
October 2, 2017
If your custom fields are using contexts, then the values/descriptions of those custom fields are bound to the specific project where that context was created.
Hence other projects could use the same custom field, but have different possible field values, or a different descriptions.   But that alone doesn't explain why switching project types would change that.
What project types are you changing between?
The other thought is that this could be a field configuration scheme problem.  I am curious to see if the changing of this project would automatically change your field configuration scheme in use here.  Those schemes can also control the descriptions that a custom field have on a per project basis.  So that seems like the most likely culprit here to me.
