I have a radio button field whose value I am updating during issue creation which is fetched from a workflow transition screen, but I end up getting the below exception
java.lang.ClassCastException: java.lang.String cannot be cast to com.atlassian.jira.issue.customfields.option.Option
Below is the code
FieldLayoutItem fieldLayoutItem = ComponentAccessor.getFieldLayoutManager().getFieldLayout(issue) .getFieldLayoutItem(customField);
DefaultIssueChangeHolder issueChangeHolder = new DefaultIssueChangeHolder();
CustomField customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(customFieldId);
CustomFieldManager custFieldMgr = ComponentAccessor.getCustomFieldManager();
<--Get the value which was set in the radio button-->
Option optionValue = (Option)mIssue.getCustomFieldValue(custFieldMgr.getCustomFieldObject("customfield_" + customFieldId));
System.out.println("Option value "+optionValue.getValue());
issue.setCustomFieldValue(customField, optionValue.getValue());
ModifiedValue modifiedValue = new ModifiedValue("", optionValue.getValue());
customField.updateValue(fieldLayoutItem, issue, modifiedValue, issueChangeHolder);
How can I resolve this issue , I am able to get the values set in the customfield but due to this cannot update the values when the issue is created.
Hi
Does it work if you change these two lines as shown below?
issue.setCustomFieldValue(customField, optionValue);
ModifiedValue modifiedValue = new ModifiedValue(null, optionValue);
Regards
AI-curious? This series walks you through building Rovo Agents step by step, no matter your experience level. Multiple workshops available throughout October and November!
Register now
