×How to find the list of customfileds where defualt value is set and context is global
Im using MSSQL DB
can some one plz help
This might give you some pointers https://developer.atlassian.com/display/JIRADEV/Database+Schema#DatabaseSchema-Customfieldconfigurationdefaultvalue
Hi there,
I believe it should be under customfield value:
select id, cfname, defaultvalue from customfield;
Please modify the above SQL to suits SQLServer
Hope this helps!
Cheers, Vicky.
