I need to query external SQL server,
select * from XYZ where customfield_10300 = project_id
or better, execute procedure
exec give.me.data {customfield_10300}
Is it possible?
I have bought plugin below but it doesn't cover my needs.
You can do it the Power Database Fields PRO. It is called Dynamic queries. Kindly read here
https://confluence.cprime.io/pages/viewpage.action?pageId=6556967
Yes, but it doesnt work as i want it to...
I can't configure it so it would refresh when opening an issue.
This customfields can only be either as a select list or autocomplete.
Or maybe i'm missing something.
Use case is to have a field that queries database with every issue refresh.
It must work like this. What is in your case? When is it refreshed?
Alexey,
As i see it, i can only connect a datasource, and create a customfield which will be filled while creating or editing issue.
Then it works.
My case:
Let's say i have an existing issue with customfield customfield_10300. This is normal number customfield.
And i want to add NEW customfield that will query external SQL and display data basing on existing customfield's 10300 value.
Ok, suppose you have a number field with customfield_10300. Then you add a new field which must select data from the database, filtered by the value of the customfield_10300. Then you need to create a new Database Pro Field with a query like this
SELECT id, col2, col3, col4 FROM testTable WHERE id = {customfield_10300}
In this case the values in the new database field will be taken from the database filtered by the value in customfield_10300.
Alex,
Customfield select is not an issue.
Let me explain again.
I've added a database customfield testdbinfo:
Then, i've added it to the desired screen:
Then, i've checked if it is working... it is.
It shows value only when I edit and set it manualy.
But, the problem is, that it's not showing on the issue screen by default.
I want to add one field that will automaticly show on all issues.
I think I understood your question. You mean that it is not on the view screen unless you chose a value for the field. If so then it is how custom fields behave. They can be seen on the view screen if there is a value. If there is no value, then it will be hidden. That is how Jira works.
So maybe this is a feature for the future, to show external info in the issue view. I think many people would benefit from it.
