Customize Jira with my own css
Joakim Norinder
May 13, 2012
I would like to customize all pages in Jira completely with my own css files. I have tried using the web resource plugin module but the css files are not placed in the bottom, thus they are overridden by Jira default css files. In some way I would like to override the default Jira css files.
What is the best way to do this? Is it even possible?
2 accepted
16 votes
Alejandro Conde Carrillo
April 10, 2013 edited
You can also add you CSS directly in the announcement banner like this:
<style type="text/css">
#details-profile-fragment {
display: none;
</style>
9 votes
kevinp
I've had pretty good success with this method,
Jira loads a version of jQuery on the page, so I utilize the announcement banner and jQuery to reload the stylesheets...
Deleted user May 13, 2012 edited
Yes, you can also simply use
<LINK href="http://jiraserver/includes/my_css_files/mystyle.css" rel="stylesheet" type="text/css">
in the Announcement Banner to link your own *.css files
Like • Klaus Moser likes this
Sandro Herrmann [Communardo]
December 21, 2012
I hope I'am not to late for my answer. You can use the CUTE Plugin to style your JIRA or Confluence in a clean and simple way. CSS Javascript and Template Code can be defined and bundeled into extensions with this plugin.
Some example extensions are provided here. You can import them to your system.
Hanae alahcen
hi sandro
i would like to try the plug in to show it to my managers
is there a way to install the trial version in juste on instance and not globaly ?
Szilvia Képesi January 18, 2015
Hi Sandro, Is it possible that this plugin only available for prod version? We have on demand cloud version and I do not see in the list of avaiable add on.
I don't know if this is the best way, but I use a <style> tag inside the Announcement Banner for modifications to the Jira css. I use Firebug to find which classes need to be overriden and I just simply paste the code inside the banner.
Also you can edit the css files located inside the jira installation. But I have never done that.
The "Look and Feel" section is also very useful.
Joakim Norinder
May 13, 2012
Thanks for your reply! For small changes I guess it's acceptable to use the Announcement Banner. For large changes I would say no. If you modify the Jira css-files I think you open the door to maintenance hell. Imagine merging css changes after an upgrade...
After having thought and searched a bit more the best solution I've found so far is to use the web resource plugin, add <dependency>jira.webresources:global-static</dependency> to the atlassian-plugin.xml, and to take advantage of css specificity.
Any other ideas?
Hanae alahcen
hello Miroslav,
i'm also interested by changing the look and feel of JIRA
i inspect every element in firebug to know where can i make my changes
the question is after doing all my changes how can jira recognize that ?
do i have to redeploy JIRA ? if it's so ? how ?
i made a security copy of jira so i can loose nothing
i'll be happy to know how to do all this
thanks for your answers
Yes, you can also simply use <LINK href="http://jiraserver/includes/my_css_files/mystyle.css" rel="stylesheet" type="text/css"> with your own *.css files
Register now
