Customize Log work Screen
Raju AD June 7, 2017
I want to add a Custom Filed in Log Work screen, can we do that? Or do we need to purchase the Add-in for that.
Tarun Sapra
Tarun Sapra
June 7, 2017 edited
Nic Brough -Adaptavist-
June 7, 2017
You will need add-ons to inject fields into the log work screen.
Can i get the Add-ons (Name) required for Log Work screen customization.
June 7, 2017
The two I've used are Ictime and Tempo
Hauke Hörhold
August 23, 2018
Is there a tutorial for injecting stuff into the log work screen?
I want to have a checkbox on top of the log work screen, which toggles the usage of some Java code i wrote.
I'm searching for a little tutorial since days...
Register now
