×Hi there,
I tried to customize the Subtask Quickcreate- and Displayform as described here:
The section in my jira-application-properties looks like that:
jira.table.cols.subtasks = customfield_10110, issuetype, status, assignee, progress
jira.subtask.quickcreateform.fields = customfield_10110,summary,issuetype,duedate
The Customfieldvalues of existing Subtasks are displayed at Subtasksection on the Issuescreen but there is no ability to enter it at the Quickcreateform.
I also tried to configure a new default Subtaskcreationscreen which holds the Customfield, but no success neither.
I have used this feature successfully with JIRA 4.2.2. Is the custom field visible when you add the subtask using the menu choice? If the custom field appears in the standard create sub-task screen and you added it as stated, the custom field should appear in the quick create form. What custom field type are you using? What version of JIRA are you using?
