Customize "linked issues" options as a project configuration
Yen Pham
Currently the "linked issues" field is global and it's getting bloated for our org with 20+ options
As an admin, I'd like to to customize the options available in the "linked issues" field per project so that my users aren't overwhelmed with the 20+ options
Avinash Bhagawati _Appfire_
Hi @Yen Pham ,
With default configuration it is not possible to configure link types for individual project. If you are using linked issues fields in transition screens, you can use Behaviours from Script runner for Jira to display linked issue type values according to selected value of resolution.
Please refer below sample script for the same.
import com.atlassian.jira.issue.resolution.Resolution
def resolutionField = getFieldById("resolution")
def issueLinkType = getFieldById("issuelinks-linktype")
def issueLinkIssue = getFieldById("issuelinks-issues")
def resolution = resolutionField.getValue() as Resolution
if (resolution.name == "Duplicates") {
    issueLinkType.setHidden(false)
    issueLinkType.setRequired(true)
    getFieldById("issuelinks-linktype").setFormValue("Duplicates to")
    getFieldById('issuelinks-linktype').setReadOnly(true)
    issueLinkIssue.setRequired(true)
} else {
    issueLinkType.setRequired(false)
    issueLinkType.setHidden(true)
Avinash
Ollie Guan
Hi @Yen Pham ,
You can refer to the following post.
Link types differentiation by projects
