×We would like to query for users whose last login was within 1 year from current date.
I found this query from docs:
SELECT
u.username
AS
username ,
psname.propertyvalue
AS
FullName ,
psemail.propertyvalue
AS
email,
pslogincount.propertyvalue
AS
logincount,
to_timestamp(pslastlogin.propertyvalue::
numeric
/1000)
AS
lastlogin
FROM
userbase u
JOIN
SELECT
id,
entity_id
FROM
propertyentry
WHERE
property_key =
'fullName'
entityName
ON
u.id = entityName.entity_id
JOIN
SELECT
id,
entity_id
FROM
propertyentry
WHERE
property_key =
'email'
entityEmail
ON
u.id = entityEmail.entity_id
left
JOIN
SELECT
id,
entity_id
FROM
propertyentry
WHERE
property_key =
'login.count'
loginCount
ON
u.id = loginCount.entity_id
left
JOIN
SELECT
id,
entity_id
FROM
propertyentry
WHERE
property_key =
'login.previousLoginMillis'
lastLogin
ON
u.id = lastLogin.entity_id
JOIN
propertystring psname
ON
entityName.id=psname.id
JOIN
propertystring psemail
ON
entityEmail.id = psemail.id
left
JOIN
propertystring pslogincount
ON
loginCount.id=pslogincount.id
left
JOIN
propertystring pslastlogin
ON
lastLogin.id = pslastlogin.id
This seems to be what we need but the line "ORDER
BY
username;
numeric
/1000)
AS
lastlogin" is not accepted in sql server. Does anyone knows whae query we can use to replace this line? Thanks in advance
I found the solution with the help of Atlassian support.
The equivalent in SQL of:
numeric
/1000)
AS
lastlogin
Is
dateadd(ss, cast( cast(pslastlogin.propertyvalue as varchar(1000)) as numeric) / 1000,'01/01/1970') as lastlogin
I got: 'Arithmetic overflow error converting expression to data type datetime.'
Looks like its not what I need.
