Dashboard dont load
yusuf_azal October 11, 2015
I have the problem, that i cant load the Dashboard in a Network.
servername:8080/secure/Dashboard.jspa - dont load
But on the server it can be load
localhost:8080/secure/Dashboard.jspa - load
I think this issue has surfaced after the update from JIRA 6 to JIRA 7.
What can i do ?
Nic Brough -Adaptavist-
October 11, 2015
If it can be loaded locally on the server, then the problem is being caused by your network - you'll need to check the route between the client and the JIRA server.
yusuf_azal October 13, 2015
Hi Nic, I dont think that caused by the network. Or do you know why all the another pages can be loaded and the dashboard not ?
October 13, 2015
Ok, so testing other pages is a good thing, but I think you need to explain "does not load" in a bit more detail - is it a white blank page? Just the menu? Is it when you're logged in only (i.e. anonymous users who haven't logged in yet are ok). Gadgets appear but no content for them? Also, how much have you got on this dashboard - is it a couple of gadgets or 25?
Register here ⬇️
