I found a description of the problem in the documentation.
https://confluence.atlassian.com/jirakb/how-to-fix-gadget-titles-showing-as-__msg_gadget-813697086.html
But none of this is my case.
In log :
http-nio-80-exec-10 ERROR admin 853x107x1 nk162p 1xx.xx.xx.xx /rest/config/1.0/directoryitems/local.json [c.a.g.r.internal.http.HttpClientFetcher] Unable to perform a request to: http://jiraxxx.xxxx.com/rest/gadgets/1.0/g/messagebundle/en_US/gadget.common%2Cgadget.roadmap
java.net.UnknownHostException: jiraxxx.xxxx.com
at java.net.InetAddress.getAllByName0(InetAddress.java:1280)
at java.net.InetAddress.getAllByName(InetAddress.java:1192)
at java.net.InetAddress.getAllByName(InetAddress.java:1126)
at org.apache.http.impl.conn.SystemDefaultDnsResolver.resolve(SystemDefaultDnsResolver.java:45)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:112)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:373)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:381)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:56)
at com.atlassian.gadgets.renderer.internal.http.WhitelistAwareHttpClient.execute(WhitelistAwareHttpClient.java:49)
at com.atlassian.gadgets.renderer.internal.http.ShindigApacheClientAdapter.execute(ShindigApacheClientAdapter.java:41)
at com.atlassian.gadgets.renderer.internal.http.HttpClientFetcher.fetch(HttpClientFetcher.java:47)
at org.apache.shindig.gadgets.DefaultMessageBundleFactory.fetchBundle(DefaultMessageBundleFactory.java:138)
at org.apache.shindig.gadgets.DefaultMessageBundleFactory.getNestedBundle(DefaultMessageBundleFactory.java:111)
at org.apache.shindig.gadgets.DefaultMessageBundleFactory.getBundle(DefaultMessageBundleFactory.java:79)
at org.apache.shindig.gadgets.variables.VariableSubstituter.substitute(VariableSubstituter.java:47)
at com.atlassian.gadgets.renderer.internal.GadgetSpecFactoryImpl.getGadgetSpec(GadgetSpecFactoryImpl.java:127)
at com.atlassian.gadgets.renderer.internal.GadgetSpecFactoryImpl.getGadgetSpec(GadgetSpecFactoryImpl.java:83)
... 2 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:185)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:136)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
at com.sun.proxy.$Proxy3337.getGadgetSpec(Unknown Source)
at com.atlassian.gadgets.directory.internal.impl.AbstractDirectoryEntryProvider.getGadgetSpec(AbstractDirectoryEntryProvider.java:39)
at com.atlassian.gadgets.directory.internal.impl.GadgetSpecProviderDirectoryEntryProvider$2.apply(GadgetSpecProviderDirectoryEntryProvider.java:110)
at com.atlassian.gadgets.directory.internal.impl.GadgetSpecProviderDirectoryEntryProvider$2.apply(GadgetSpecProviderDirectoryEntryProvider.java:107)
at com.atlassian.gadgets.directory.internal.impl.AbstractDirectoryEntryProvider.lambda$entries$0(AbstractDirectoryEntryProvider.java:29)
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193)
at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:948)
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708)
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499)
at com.atlassian.gadgets.directory.internal.impl.AbstractDirectoryEntryProvider.entries(AbstractDirectoryEntryProvider.java:31)
at com.atlassian.gadgets.directory.internal.impl.DirectoryImpl$1.apply(DirectoryImpl.java:48)
at com.atlassian.gadgets.directory.internal.impl.DirectoryImpl$1.apply(DirectoryImpl.java:45)
at com.google.common.collect.Iterators$6.transform(Iterators.java:785)
at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:47)
at com.google.common.collect.Iterators$ConcatenatedIterator.hasNext(Iterators.java:1332)
at com.google.common.collect.TransformedIterator.hasNext(TransformedIterator.java:42)
at org.codehaus.jackson.map.ser.std.IterableSerializer.serializeContents(IterableSerializer.java:34)
at org.codehaus.jackson.map.ser.std.IterableSerializer.serializeContents(IterableSerializer.java:15)
at org.codehaus.jackson.map.ser.std.AsArraySerializerBase.serialize(AsArraySerializerBase.java:86)
at org.codehaus.jackson.map.ser.StdSerializerProvider._serializeValue(StdSerializerProvider.java:610)
at org.codehaus.jackson.map.ser.StdSerializerProvider.serializeValue(StdSerializerProvider.java:256)
at org.codehaus.jackson.map.ObjectMapper.writeValue(ObjectMapper.java:1613)
at org.codehaus.jackson.jaxrs.JacksonJsonProvider.writeTo(JacksonJsonProvider.java:559)
at com.sun.jersey.spi.container.ContainerResponse.write(ContainerResponse.java:302)
... 5 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:159)
... 1 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:69)
... 32 filtered
at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(ExternalCustomerLockoutFilter.java:55)
... 13 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 57 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 16 filtered
at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:37)
... 19 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 5 filtered
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(CustomerContextSettingFilter.java:183)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.rteInvoke(ReentrantThreadLocalBasedCodeContext.java:136)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.runOutOfContext(ReentrantThreadLocalBasedCodeContext.java:89)
at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.runOutOfCustomerContext(CustomerContextServiceImpl.java:47)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(CustomerContextSettingFilter.java:174)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(CustomerContextSettingFilter.java:126)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(CustomerContextSettingFilter.java:115)
... 4 filtered
at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:37)
... 8 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 26 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 25 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
jira 8.2.2
OS Windows Server 2016 10.0
The (rather ill-defined, but always) root cause of this is "Jira can not call its own REST API on this machine".
Your error message is clear. When the Jira user on the server (the user running Jira) tries to reach "jiraxxx.xxxx.com", the operating system is unable to resolve that to a server.
You need to fix your DNS, such that jiraxxx.xxxx.com resolves correctly.
