Dashboard widgets sometimes stay emtpy on jira 6
Dorian BECKER August 21, 2013
I've installed jira 6 and imported data from jira 5.
Everything work perfectly but not the dashboard.
The dashboard isn't displaying correctly the widgets. Most of the time, they stay empty and activity stream display "An error occurred while trying to retrieve recent activity.".
Sometimes, some of them are displayed:
I have checked the logs and I doesn't see any errors when refreshing the page.
I have tried to disable every plugin, disable some widgets but it doesn't change anything.
It is a WAR installation on linux with ssl + proxy. Proxy +ssl are configured in sever.xml.
I have searched for hours, but i haven't seen similar problems
Thanks for your help!
Dorian BECKER June 3, 2015
It was an issue with our load balancer and our two proxy. If the main page was loaded trough proxy #1 and the request for widgets trough proxy #2 a 403 was returned.
In my case it was a session, token or ip-forwarding issue.
mark.kaye@mavenwire.com
May 14, 2015
Was a solution found for this?  I have the same issue.  Sometimes a couple of widgets will load, sometimes not, it seems quite random.
Jermaine Grant
August 27, 2013
I have the same issue, it looks like since Jira 6 the dash board is all messed up. Im using IE 8 and i have disabled view intranet sites in compatibility mode.
Tom Moors
August 22, 2013
Hi Dorian,
Can you also double-check that the base url for JIRA is set correctly, with https included?
Do you also have problems connecting to the Atlassian Marketplace?
Tom
Dorian BECKER August 22, 2013
I have checked again my base URL and the "https" is included.
A few day ago I have encountered some troubles with the Marketplace but it was before I set correctly the proxy attribute in server.xml. Now it works perfectly.
Cheers
Tom Moors
August 21, 2013
Hi Dorian,
Welcome to Answers!
The problem with gadgets not loading properly is something you can debug from within your browser, eg by using the Chrome Web Inspector. Can you verify you don't have any errors in the console in your browser?
Also, to be sure, did you set the proxyName, proxyPort and scheme attribute on the connector in your server.xml file?
Tom
Thank's for your answer!
Yes I have set the proxyName, proxyPort and scheme in server.xml.
With some web consoles (like de Firefox or Chrome ones) I see 403 on some files.
But when I clic on these links, I have any 403 and I can see files which should be widgets data (xml and json content).
I have no JS errors, juste some warnings.
If I understand right, these xml and json are parsed by some JS, so it is client-side. And I don't understand how files permissions can change if I'm still connected on jira. Moreover I have the same problem with public dashboard.
atlassian, confluence administration certification, atlassian certified professional, confluence admin for cloud, atlassian learning, confluence training, confluence certification exam, confluence cloud admin, admin credential, atlassian certification
Become a certified Confluence admin today! 📖
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
