Database Values Plugin : How to update options without restarting Jira
Pierre Cattin
October 15, 2013
I noticed that if I update or insert something in the database table used by a jdvp field, I have to restart Jira to see the change in the interface.
Is there a way to update the options without restarting Jira?
Wim Deblauwe
October 17, 2013
By default, there is a cache timeout, so it will not go to the database all of the time, unless you put that at 0. So, or you put the timeout at 0, or you wait for the timeout, or you do like you have done with disable and reenable.
Pierre Cattin
October 16, 2013
I found it! If I restart the plugin (disable and the enable), the customfield's options and values are updated, without restarting Jira.
