×Hello guys,
As a user in the Service management portal, is there any way to identify which node is in the Datacenter version?
Fabio
Hi @Fabio Manzoni, I haven't come across with that yet, so I'm interested to see how others handle it.
I tested in a few different portals I know have multiple nodes. The way I could identify the node was through inspecting the page (in my case using Firefox), network tab, post:method/file:bulk, headers/response headers, search for "node". I don't believe it's consistent, specially if there is additional layers such as api gateway, global accelerator, etc., so it depends on your setup.
Hi @Ivan Lima ,
This solution worked.
I did the same steps in Chrome and Edge and could see the right node.
Thank you for your tip.
Best,
Fabio
