Decrement Custom Field Value
AMOL
I have a Scripted custom field called FixVersion_Changed
The value of the field is updated as it captures value for number of changes made to the FixVersions field.
I would like to decrement the value of this field under certain conditions using a Scripted Post Function.
I am not a programmer and looking for a code that I can use to modify the value of this field.
3 accepted
Alexey Matveev
October 29, 2017
you need to replace
ComponentAccessor.changeHistoryManager?.getChangeItemsForField(issue, "Fix Version").size() as int
with something like this
ComponentAccessor.changeHistoryManager?.getChangeItemsForField(issue, "Fix Version").findAll{ !it.getToString().isEmpty() }.size() as int
Unfortunately I can not check the code because I have no access to Jira right now. But the idea is that you have to count all changes of Fix Version field except when it was set to Null. I am not sure what getToString returns if value were set to null but maybe it will work.
Alexey Matveev
October 29, 2017 edited
Use this code. It worked for me.
ComponentAccessor.changeHistoryManager?.getChangeItemsForField(issue, "Fix Version").findAll{ it.getToString() != null}.size()
AMOL
This is working exactly as needed. Thank you, Alexey!!
Alexey Matveev
October 29, 2017
if you use scriptrunner scripted field then you will not be able to set a value for the field in a post-function. Scripted fields work differently. The value for the scripted field is calculated on showing the field on the screen. That is why you have to change the code for the field. I guess there is an increment somewhere in the code of the scripted filed. You need to add a condition which will skip the increment on your condition. If you produce the current code of the scripted filed I can give you more details.
AMOL
Hi Alex,
That makes sense..
The Scripted field name is FixVersion_Changed. Below is the code of the scripted field.
I would like to not increment the value of this field if I transition the workflow to Backlog and Deferred. This is because I clear the FixVersion field when I transition to Backlog or Deferred as a post-function. The issue could come back in the funnel at a later date and a new FixVersion could be assigned.
Tayyab Bashir
October 28, 2017 edited
You need to add the post-function to a workflow step.
You could add a code something like this to decrement the value:
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
// Replace 12345 by the ID of your customfield
def customField = ComponentAccessor.customFieldManager.getCustomFieldObject(12345)
def fieldValue = issue.getCustomFieldValue(customField)
def newValue
// Add your conditions here
if (true){
newValue = fieldValue -1
def holder = new DefaultIssueChangeHolder()
customField.updateValue(null, issue, new ModifiedValue(fieldValue, newValue), holder)
You can modify the code, adjust it to your conditions to apply decrement.
AMOL
Thank you, Tayyab. I am going to try this out. Will let you know here.
AMOL
Getting the below error...
Also if I specify the fieldID, I get few more errors.. Again I am not a Java or Groovy programmer to decipher
Nic Brough -Adaptavist-
October 29, 2017
Use spaces in your code.  "fieldvalue-1" is a single object that you have not defined, not a calculation.  Try "fieldvalue - 1"
AMOL
Thank you Nic and Tayyab. Alexey's solution below worked for me. I do have a use case for the code mentioned above as well. Will test it soon.
Alexey Matveev
October 28, 2017
What plugin do you use for the scripted field?  Scriptrunner? If you are not sure then kindly produce the current code of the mentioned scripted filed.
AMOL
ScriptRunner.
