×Hi,
We are trying to export a whole instance to another instance, and came across this issue. We are unable to rename the Default Field Configuration and Default Workflow scheme.
what is the impact when we export all projects (whole instance) to another instance. Does it over write the target instance's Default schemes?
could you please suggest us steps, not to overwrite the default schemes in the target instance.
Note: The default schemes in both instances are Different.
please let us know about this.
Thanks in advance
Harish.
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
