Define multi level select CF value in soapUI create request
Radek Kantor
April 15, 2012
what is the correct syntax to define multi level select list custom field value in create issue request directly in soapUI? I used results from getIssue method:
<customFieldValues xsi:type="ns2:RemoteCustomFieldValue">
                  <customfieldId xsi:type="xsd:string">customfield_10243</customfieldId>
                  <key xsi:type="xsd:string" xsi:nil="true"/>
                  <values soapenc:arrayType="xsd:string[1]" xsi:type="soapenc:Array">
                     <values xsi:type="xsd:string">KC Hradec Kralove</values>
                  </values>
               </customFieldValues>
                  <key xsi:type="xsd:string">1</key>
                     <values xsi:type="xsd:string">Dvur Kralove</values>
                  </values>
but in create it returns exception:
<soapenv:Fault>
         <faultcode>soapenv:Server.userException</faultcode>
         <faultstring>com.atlassian.jira.rpc.exception.RemoteValidationException: {customfield_10243=Value: 'Dvur Kralove' is an invalid Option} : []</faultstring>
         <detail>
            <com.atlassian.jira.rpc.exception.RemoteValidationException xsi:type="ns1:RemoteValidationException" xmlns:ns1="http://exception.rpc.jira.atlassian.com"/>
            <ns2:hostname xmlns:ns2="http://xml.apache.org/axis/">WV420035</ns2:hostname>
         </detail>
      </soapenv:Fault>
Radek Kantor
April 16, 2012
Problem solved, documentation is casual. As value for parent and child must be an option ID used, not string name representation.
Nathan
I'm stuck with this same error (for a custom cascading select).
Could you explain how you did it in more detail? What does your final XML look like?
