×Hi there,
may you can help:
We have issue in a project A being linked via link type "relates to" to issue of different projects (B,C), If the status of the issue in A changes I would like to delete the "relates to" link to an issue in project B and keep the linbk to the issue inm project C.
How could I implement it. Any help is highly appreciated.
Kind Regards
Johannes
It's not a super elegant solution because you're limited to what automation allows you to do but I was able to get it somewhat working with this: link
For this to work properly, you will need to import this as a global automation and update the project references in the condition and JQL lookup as necessary.
Some possible caveats depending on your use case:
Hi @Johannes Fünger ,
you need a custom post function to do that. Do you have ScriptRunner app?
Fabio
I am working in DC environment on similar case where the customer need is to remove only specified "relates to" links that linked issue summary contains a specific text. Deleting all "relates to" is not option.
I have not figured out how to achieve this, so all new ideas are welcome.
