We have a few old projects that I thought I deleted, and none of the admin users can access them -- I verified our permissions. The projects shows on the list of 'View all projects', however, when we click on one - it says the project is no longer available (indicating it's been deleted).
How do we fully delete it or remove it from our list?
hope below info helps you.
This did not help for what I was looking for, but I was able to figure it out. Thanks!
Glad you resolved the issue :-). May i know how did you do it?
I was originally attempting to go to the project so I could get to the settings and push "Delete project" in the left navigation (like I have done with other projects). However, it would not allow me to get to the project (like it was already deleted or something.
I then went to the 3 lines on the bottom left, and went to Jira to get to my main page/settings. Choose Settings ->Projects->Projects. This will show a list of your projects and on the far right are the "actions" you can take (edit or delete). I was able to delete the projects on this page.
This may not be the case for everyone...but it helped in my situation! =)
