I'm looking for documentation explaining how the dependencies in portfolio work -
Best,
-Noam
@Noam Guttman you will see two signts
+: if you use this , it means the current issue which you selected have blocker to another issue which you will select .
- : if you use this it means , the current issue is being blocked by another issue.
For example
You selected issue-1
if you click on + and add issue -2 it means issue-2 is blocked by issue-1
If you click on - and add issue-3 , it means issue-13 is blocked by issue-1
Hopefully its clear now.
