Detecting when an issue is closed
amiddleton October 3, 2017
Hi
I've written a plugin to update our summary database with bits of information from JIRA. I have an eventlistener that does stuff when an issue gets created, updated or closed.
The method is pretty simple
{CODE}
public void onIssueEvent(final IssueEvent event) {
Long eventTypeId = event.getEventTypeId();
Issue issue = event.getIssue();
log.debug("Issue {}, generated eventtype {}", issue.getKey(),
eventTypeId);
// on insert or update
if (eventTypeId.equals(EventType.ISSUE_CREATED_ID)
|| eventTypeId.equals(EventType.ISSUE_UPDATED_ID)) {
log.info("Issue {} has been created at {}.", issue.getKey(),
issue.getCreated());
createSvr(event);
} else if (eventTypeId.equals(EventType.ISSUE_RESOLVED_ID)) {
log.info("Issue {} has been resolved at {}.", issue.getKey(),
issue.getResolutionDate());
} else if (eventTypeId.equals(EventType.ISSUE_CLOSED_ID)) {
log.info("Issue {} has been closed at {}.", issue.getKey(),
issue.getUpdated());
closeSvr(issue);
{CODE}
The problem is that it seems to detect successfully when a JIRA issue is created or updated, but the closed function never gets called.
I tracked an issue down in the logs for when it gets closed in the workflow and all I get is
Issue OPS-22979, generated eventtype 13
I'm not sure what eventtype 13 is but it certainly isn't invoking the closed code. The resolved code never seems to get called either.
Can anyone propose how I can successfully detect closure of tickets please?
Mizan
October 3, 2017
Can you check in the workflow transitions post function that the 'Issue Closed' event is being fired when the issue is closed.
It may be possible that when issue is closed this event is not fired. Sorry , even I am not sure about eventtype 13
(I suspect that a generic event is being fired instead, Normally when the workflow is changed we forget to update the events accordingly and live with the generic event)
Thanks - I'll get one of the team to look into it
Brilliant - that has fixed it.
Logistics1520 August 3, 2023
Thank you. It works for me too.
Set Workflow - transaction - Post Functions to "Fire a Issue Closed event that can be processed by the listeners." and now my notifications works.
Register Now
