Difference between FC and FCS?
Manoj
Hi All,
What is the difference between Field Configuration and Field Configuration schemes? Could you please simplified.
M
Prakhar Srivastav {Appfire}
March 5, 2019
@Manoj
You can associate your Field Configurations with Issue Types with help of defining Field Configuration Scheme.
So in simple words you can have different Field Configuration for different issue type.
Regards
Prakhar
Manoj
Thanks Prakhar, than i am on right track of understanding...
Have you ever created cascading drop down list dependent one.
M
March 5, 2019
@Manoj
Yes you can create cascading drop down list.
If you feel that my answer has helped you then kindly accept the answer.
Regards
Prakhar
Manoj
Hello Prakhar,
Is there any way to limit the custom fields for assignee.
As I have to assign few tickets to a assignee and i want him to see only few fields while creating a ticket.
looking forward for your response.
M
Register now
