Could you please tell me what is the difference between JIRA rest and Native API with respect to usage (adaptability) , and response time , majorly when should each of them be used (also which of them is preferred to be used across various versions of JIRA).
I found a documentation for list of Rest API's for JIRA : https://docs.atlassian.com/jira/REST/latest
Is there a similar one for Native API's as well?
There's not really much use in such a comparison.
Let's put it this way - the REST API is provided by a block of code that uses the native API. It's a way to expose parts of the internal API to remote calls.
The question about usage is easy though. If you are writing an add-on for JIRA Server, you have access to the internal APIs, so use them. In all other cases, use REST.
See https://developer.atlassian.com/jiradev/jira-apis for all of them
Basically we are creating a interface to synchronize data between JIRA and External Tool, which is bidirectional data transfer. so it includes reading data from JIRA and writing to JIRA (GET,PUT,Post calls).
Also could you precisely share the link for the list of Native API's and its functionality (for our reference)
So, are you going to be writing an add-on for JIRA to do this? Or do you want to keep it all external?
Ok, that makes it really simple.
You don't care about these questions. You have to use the REST API to do this work, so the differences between it and the Java API are not relevant.
