Difference between screen schemes and issue type screen schemes?
Anand Vardhan
Can anyone elaborate the difference between screen schemes and issue type screen schemes? Would be great if it can be explained with an example.
2 accepted
4 votes
Gezim Shehu [Communardo]
July 29, 2019 edited
Theoretically
Screen Scheme - Defines which screens are going to be used for which operation (create, view, edit)
Issue Type Screen Scheme - Defines which Screen Scheme (above) is going to be used for which issue type
Here's an example
You have 2 screens:
  1. Screen A (Summary, Description, Due Date)
  2. Screen B (Summary, Description)
You create  Screen Scheme 1 "Screen Scheme A" with
  1. Create - Screen A
  2. Edit - Screen B
  3. View - Screen A
You create  Screen Scheme 2 "Screen Scheme B" with
  1. Default (Screen B)
You create a new Issue Type Screen Scheme "Issue Type Screen Scheme X" with
  2. Bug (Screen A)
So, as a recap , now when a project has specified "Issue Type Screen Scheme X", on issue type:
  • Bug - You will be able to set Due Date while creating and also view it, but you will not be able to edit
  • Any other issue type - You won't have field Due Date at all
Cheers
Anand Vardhan
Thanks a ton!
Fahad Siddiqui
August 26, 2019
Dear Gezim Shehu,
What is issue type and issue type schemes?
lakshmi
just a small correction to above answer
Issue type <-> Screen scheme
hence
  1. Default (Screen Scheme B)
  2. Bug (Screen Scheme A)
Like • 4 people like this
karim -Atlassway-
Banned
Hi @Anand Vardhan
Example you have 3 issue type (Bug , Error , Task) , and you need to have differents screen for each one , so in this case you need to have for each issue type a screen scheme .
Note: Screen scheme contain Create , Update and view  ... screens.
So if you have not this requirement , mean you have the sames screens for all issue type , you do not need to get a screen scheme for each issue type .
Hope it's clear for you now
Regards
Anand Vardhan
Gregory Pakosz December 29, 2021
The confusing part in the original documentation is that it says "Screen Scheme ... OR Issue Type Screen Scheme ..."
atlassian, state of product 2026, product teams report, developer experience, product manager survey, AI impact, product team stress, product teamwork, dev workflow insights, 1000+ PMs, product leadership research
State of Product 2026
State of Product 2026: your pulse check on product development today. We asked 1000+ real teams how they’re feeling–and they had a lot to say.
Get the report
