Hi There,
Can we provide different permissions for different issue types?
Consider, I have a project with the issue types Epic, Task and Sub-task. The permissions should be as below:
EPIC - CREATE -> Myself and another person
EDIT -> Current assignee and the above two people
TASK &SUB-TASK - CREATE & EDIT -> Open to all developers
In the permission schemes, it is mentioned just the issues, but not specific to types. Could you please let me know if there is a way to achieve it?
Thanks and Regards,
Keerthana Bhuthala
Hi Keerthana,
No. This is not supported (and will not be supported) by Jira due to the added complexity. Have a look at JRACLOUD-42116 and JRASERVER-5865 to better understand the reasons behind this decision.
For the create permission, however, there is a workaround: You can use a separate workflow for Epic and in that workflow you can add a condition to the create transition. The creation of an issue (from the gray circle to the first status) is seen by Jira as a transition in the workflow. Have a look at the documentation article below to understand how you can add a condition to that transitions so that only certain users can perform it:
advanced-workflow-configuration
Claudiu
Hi @Claudiu Lionte ,
You mentioned there is a workaround for create permission by adding a condition. In the case of Jira Cloud, Conditions are not available, only Validators and Post Functions. And the options in Validators are limited to permissions. Is there a workaround to restricting creation of issues in Jira Cloud by Roles instead of Permissions?
Thanks and Regards,
Marianne Lee
