Disable Confluence updates in Jira activity stream
Zach Newman
We are currently using Jira 5.1.1. A project with an application link to corresponding confluence project is showing completely unrelated confluence updates in the activity stream. Is there a way to fix this? The activity feed is unusable because it is spammed with updates from different projects.
Zach Newman
Atlassian support confirmed this is a bug with our version of Jira and Confluence.
Andy Nguyen
January 25, 2014
You can edit the Activity Stream and remove Confluence or restrict the content to be displayed:
Andy
Jo
How would you restrict the content to be displayed? and also, how do you remove the activity stream from projects ? ( I managed to remove it from the main dashboard but i`m still fumbling in the dark with the projects )
jing_hwa_cheok
January 10, 2014
Hi znewman,
You may find this documentation useful https://confluence.atlassian.com/display/JIRA/Adding+the+Activity+Stream+Gadget.It contain the detailed instruction on how to select the application activity that you wish to monitor.
Hope this helps!
Jing Hwa
Zach Newman
I am referring to the Activity Stream on the project summary page
