Disable Customer visible Transition from Customer Portal
Madhu Reddy
December 31, 2020
We have added 3 customer visible transitions for Service Management Project workflow.
I want to disable that 3 transitions after 5 days of Ticket closure.
We don't want our customers to go back to the old ticket and reopen it. If they face the same issue after few days we wanted them to create a new ticket instead of reopening the old ticket.
How to disable customer visible transitions from the Customer portal after 5 days of ticket closure.
See in the attached screenshots the ticket is closed and still the 3 transitions are available for customers.
David Fischer
With JMWE, you can create a Scripted (Groovy) Condition on the transition, with the following script:
!issue.get("Closed on") || new Date() <= issue.get("Closed on") + 5
However, that also requires that you memorize the date the request was closed, in a "Closed on" Date/Time Picker custom field. For that, you need to create the field and use a Set Field Value Post-function on the Close transition with the following setting:
- field: Closed on
- value type: Groovy Expression
- value:
new Date()
Madhu Reddy
January 14, 2021
@David Fischer Thanks a lot for your inputs, It worked for me.
Madhu Reddy
January 16, 2021
Hi @David Fischer Could you help please us with the below linked requirement as well if you have an idea. Thanks in Advance.
https://community.atlassian.com/t5/Jira-discussions/Disable-comment-on-a-closed-issue-after-5days/mp/1581192#M12446%3Futm_source=atlcomm&utm_medium=email&utm_campaign=mentions_comment&utm_content=topic
We would like to disable the comment option after 5 days of ticket closure.
We are able to disable comment option using "jira.permission.comment.user" transition property. But we want to allow users to add comment up to 5 days of closure and then after we would like to disable comment option.
Madhu
David Fischer
Hi @Madhu Reddy ,
The link doesn't work. But anyway, I don't believe you can prevent customers from adding a comment only on specific issues. All you could do is send them an automated notification email telling them to open a new request instead.
David
Madhu Reddy
January 16, 2021
Hi @David Fischer We can disable comment option by adding property ( "jira.permission.comment.user" = Denied ) to the transition. So on the closed transition we can add the above property to disable comments.
But my requirement is to disable comments 5 days after closing the ticket. ( Status = Closed AND resolved > 5d ). Then we have to disable comments.
Hope my requirement is clear now.
Thanks for your suggestions, Please have a look if there is any possible way to achieve my requirement.
Madhu
David Fischer
January 16, 2021 edited
@Madhu Reddy your requirements were pretty clear. But the jira.permission.comment.user property is a workflow step (which is the workflow equivalent of a Status) property, so it will apply to all issues in that step (status). You can't set that property at the issue level.
As I said, Jira doesn't support disabling comments at the issue level, and commenting an issue is not considered as a workflow transition and thus Workflow Conditions cannot be used either.
The only thing I can think of is using ScriptRunner Behaviors, assuming they work on the customer portal which you'd need to check with Adaptavist.
And anyway, even that won't prevent customers from creating a comment by replying via email...
Daniel Ebers
January 1, 2021
Hi @Madhu Reddy
you could try to set a validator/condition on the workflow which the criteria you need.
For a requirement like this we used Script Runner in the past using a JQL compare condition. If the issue is closed for longer than 7 days the transition will not be displayed.
Please also review:
https://confluence.atlassian.com/adminjiraserver/advanced-workflow-configuration-938847443.html
Daniel
Madhu Reddy
January 1, 2021
Hi @Daniel Ebers Thanks for the information.
We don't have Script Runner addon. We have Automation for Jira and JMWE.
Is there any possibility with those addons.
Regards
Madhu
Daniel Ebers
January 1, 2021
Ah okay, I see :-/
I'm pretty sure some users experienced with those two Apps read here also and will probably chime in.
Like Madhu Reddy likes this
