Is there a way to disable a JMWE function on the post-function transition?
I don't want to delete it; I want to disable it. In this case, I will enable it in future usage.
Thank you,
Regards
Hi @Salim Richa
This functionality is coming soon to JMWE. But in the meantime, you can enable Conditional Validation and use this script:
{{false}}
