Hello
When my issue is certain status I would like to disable link option from this ticket. Please let me know how this can be done.
Abe
Hi @AbrahamA
This can be done via Workflow properties by adding a property to the status that you want to remove the linking option/permission.
Enter the permission property into the Property Key field. The property is of the form - jira.permission.[subtasks.]{permission}.{type}[.suffix]
So, perhaps the property to achieve what you want would be in the way:
jira.permission.link.denied
with empty value
Personally I haven't used this permission but I have used other workflow properties on statuses, here are a few examples:
Kindly review the workflow properties page and check on your Jira version and test if jira.permission.link.denied does the trick.
David
ServiceRocket
