Disable ability to update priority
Stephane Renou
I would like to disable the ability to the developpers to update the priority of an issue. I could not find a way to do that in Jira.
MinC
December 4, 2011
Probably you can check out the features provided by this plugin as it seems this might what you need: Field Security Plugin for JIRA
Jobin Kuruvilla [Adaptavist]
December 4, 2011
You might also want to look at workflow operations! If you create a workflow operation to update priority (only priority will be on the workflow transition screen!), you can then limit it to individuals , groups or project roles using workflow conditions.
Stephane Renou
So I guess this means creating a transition for each state where I want to be able to change the priority, and limit this usage to only the people that should be able to do it. Then the default screen would not show anymore the field. I guess this would make the trick, thanks
Hugh Prior
December 4, 2011
Since you can define whatever screens you want, I would think you could just define custom screen(s) without the field for any screen where the user can currently change it and you don't want it changed.
You might also take a look at using a Field Configuration which hides the field.
Stephane Renou
Thanks, my concern is that I want some users to be able to change priority but not all of them, and I was not seeing how to assign custom screens to only specific people. I guess I would need to go with the plugin solution.
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
