Disable custom fields in View screen by using IfDisable is inconsistent
Meital May 26, 2020 edited
I'm using Live Fields (Power Script) and would like to disable some of the fields in the View screen. In order to do so, we are using IfDisable option in our script.
if (argv["screen"] == "view"){
    lfDisable("customfield_XXX");
    lfDisable("customfield_YYY");
Customfield_XXX is a drop down field and is disabled as expected
Customfield_YYY is a URL field and is not consistent with the disable mode. When accessing the issue the field is enabled, after refreshing the page it becomes disabled. Also, after editing the issue and returning to the view page the field is disabled. However, going to another issue and then getting back again to the old issue, the field is enabled again.
Is this a bug? any idea how this can be fixed?
Meital
Alexey Matveev
July 22, 2020
Hello @Meital ,
If this bug is still valid for you. Please, register a ticket in Cprime support system:
https://marketplace.atlassian.com/apps/43318/power-scripts-jira-script-automation?hosting=cloud&tab=overview
I also have the same problem with the URL field.
