Disable edit option for gadget
Xavi fernandez November 16, 2017
I'm developing a gadget without using the " Atlassian Gadgets JavaScript Framework" so I want to know how to quit the "edit" option from the gadget menu, because i'm managing config by my own.
cheers.
Aleksandr Zuevich
November 18, 2017
Hi Xavi,
usually when you describe gadget you use AJS.Gadget and you just need not to specify config parameter if you don't want to see edit option in the gadget menu.
But you've written that you don't use Atlassian Gadgets Javascript Framework. So provide us with detailed information how you describe your gadget.
Xavi fernandez November 23, 2017
Any way to do it without using AJS.Gadget?
Thanks.
Register today
