Disable issue type javascript
Yannick Le Goualher June 20, 2015
I've  updated my JIRA instance in from 6.3.15 to 6.4.6.
I used a script to disable some issue type with javascript for group of people on the issue creation screen, but my script doesn't work anymore and I don't understand why.
jQuery(document).ready(function($)
            JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function(e,context) {
                $("#issuetype option").each(function()  {
                    if( $(this).text().trim() == "Type1" || $(this).text().trim() == "Type2")
                         $(this).remove();
It seems that this script is not executed.
It worked perfectly in 6.3.15.
Has anybody an idea?
Thank you
Stephen Deutsch
June 24, 2015
We just recently upgraded to 6.4 and I had to figure it out as well. It seems like the select has been replaced with a single-select that pulls the information from another source, so this is what I did to remove the issue types. It's not so elegant, but at least it works OK. It should actually work on 6.3 as well.
jQuery(document).ready(function() {
  var removeIssueType = function() {
    jQuery("a[title='type1']").parent().hide();
    jQuery("a[title='type2']").parent().hide();
  var findIssueType = function() {
    jQuery("span.drop-menu").click(removeIssueType);
    jQuery("#issuetype-field").keyup(removeIssueType);
    jQuery("#issuetype-field").click(function() {
      setTimeout(removeIssueType, 1);
    jQuery("#project").change(function() {
      setTimeout(findIssueType, 1000);
  if (AJS.params.loggedInUser !== "allowed.user") {
      findIssueType();
    setTimeout(findIssueType, 500);
That should be enough to get you started for any customizations.  Just replace "type1" and "type2" with the types you want to remove.
Suresh
we have JIRA 7.0.2, but script is not working correctly, I am doing any mistake,Please let me know,
Thank you for the help.
    jQuery("a[title='Core Patch Request']").parent().hide();
    jQuery("a[title='Customization Patch Request']").parent().hide();
      findIssueType();
Stephen Deutsch
April 1, 2016
Yeah, sorry, I guess I never updated it since they removed the title element sometime during the 6.4 development process.  This version should work (just tested it with the latest version of JIRA Cloud):
<script>
    jQuery(".aui-list-item-link").filter(function(){
	  return jQuery(this).text() === "Core Patch Request" || jQuery(this).text() === "Customization Patch Request"
	}).parent().hide();
    findIssueType();
</script>
Like • Maggie Gu likes this
Vladimir Sid
Hey, @Stephen Deutsch is there a possibility to use project category instead of project name ? Like there are many projects which needs to hide few issuetypes and needs to be hidden based on category. Thank you so much.
Rajesh Ramankutty
Hi Team,
kindly tell me where we need to use this code to hide the issue type in jira?????
Peyyala Madhusudhana Rao August 9, 2017
I am facing the same problem. Can i have sample code snippet please.
Yannick Le Goualher June 26, 2015
Hi it works fine, thank you very much for your help!!
Yannick Le Goualher June 25, 2015
thank you for your answers. I'll test it tomorrow and give you my feed back.
Christophe Promé
This is because Atlassian switched to AUI Select 2 component :
<div class="aui-list" id="issuetype-suggestions" tabindex="-1" style="display: block;">
    <div class="aui-list-scroll" tabindex="-1">
        <ul class="aui-last">
            <li class="aui-list-item aui-list-item-li-bug active"><a class="aui-list-item-link aui-iconised-link" href="#" title="Bug"><img class="icon" alt="" src="...">Bug</a></li>
            <li class="aui-list-item aui-list-item-li-epic"><a class="aui-list-item-link aui-iconised-link" href="#" title="Epic"><img class="icon" alt="" src="...">Epic</a></li>
            <li class="aui-list-item aui-list-item-li-technical-task"><a class="aui-list-item-link aui-iconised-link" href="#" title="Technical Task"><img class="icon" alt="" src="...">Technical Task</a></li>
        </ul>
    </div>
</div>
You have to adapt your code and remove the aui-list-item element corresponding to the issue type you want to remove, they all have a specific class:
etc ..
Beware though, this element is appended to the DOM when the user focus the issue type select.
It seems that the <select id='issuetype' has disapeared...
I don't know how to adapt my script. I only find div
Help us plant more trees
