×Hello,
I use EPICs for grouping tasks/stories (like a generic integration to a specific customer of mine) and I don't want used them otherwise (for log work). The works are logged on tasks or on stories.
Can I disable "log work" just for EPICs?
Thanks.
Hi Eitan,
You may prevent users from logging time in Epics by following these steps:
After applying this property, users will see an error on trying to log work on an Epic, preventing them from recording worklogs in Epics.
Hope it helps.
Great Ignacio!
Thank you Ignacio! This is a real help. Do you know where can I learn more about available properties like this one ?
Sure! There's a good article about workflow properties here:
https://www.j-tricks.com/tutorials/permissions-based-on-workflow-status
Nice one!
One small addition, according to Atlassian, property value should be "denied" . But I noticed that it also works with an empty value.
More information can be found here: https://confluence.atlassian.com/jirakb/how-to-restrict-log-work-on-a-specific-status-834225982.html
should this control be applied to every project manually or you have any global settings?
Eitan,
I think that this cannot be done out of the box.
You can try with an listener, capturing the work logged on issue events and delete them, but this is counterintuitive for the end user and one thing more to maintain and check.
Maybe the best solution is user education and to exclude the epics from the queries / reports you use for time tracking.
I have heard that workflow may solve that, but I don't know how.
As the link - I didn't understand how to link a workflow to an epic (It just create a new workflow).
