I need to display the difference between a custom date and the created date in days, but it's displaying in minutes unless I specify as "hour", in which case it displays in hours.
Here's the script:
secondsBetween(issue.get("Code Review Actual Date"), issue.get("created"), "day")
Is this possible?
Hi @Teressa Reed sorry, I never used this App, but I checked the documentation and it looks like you can adjust velocity template to display the value in required format:
Thanks for the info. I haven't had a chance to give it a try, but I plan to work on it again on Monday and will let you know how it goes.
Thanks again,
Teressa
