Hi team,
I have a project which has epics and tasks under the epics. Let's say Epic 'E' has the below fields:
field1: test1
field2: test2
and the task 'T' which is created under Epic 'E' has the below fields:
field3: test3
field4: test4
Now, I would like to display the task info as well as epic info in the Issue Navigator screen alongside like below:
Columns should be like: | Task Name | Epic Link | field1 | field2 | field3 | field4 |
Values should be like: | T | Link to E | test1 | test2 | test3 | test4 |
Is this possible in JIRA?
Thanks and Regards,
Keerthana Bhuthala.
Not an option using this method I'm afraid - the issue search provides data for just the issue being viewed - so on an Epic you'll see only Epic field data, not field data from any other child issue alongside it in the same row.
An option which gets you some of the way:
^ This gives you a view of fields across multiple levels in a similar vein - not sure if this is useful in your specific case though :)
Register now
