I'm using a post function, which is meant to fail depending on the field values.
Is there a way to display the postfunction error log to the user on the Jira issue screen.
Please advice.
Thanks.
No, there's no display functionality SR can hook into on post functions. You need to trap the error and write it into a field on the issue.
Hi @Nic Brough -Adaptavist- Is there a way to push the error into a field?
Since the error is shown in the logs, I'm not sure of a way to capture the error and push it into a field.
Please advice
Thanks.
You need to catch the error in your code. I can't really tell you more than that.
