×You can also change the number of issues displayed per page in your personal user preferences. :)
And now, in 2021, there's no such animal in my Profile or Personal Settings pages, at least in the Cloud version. Anyone else know how to change the number of issues displayed per page when viewing search results?
I'd actually like to lower it from 50 to something like 10 because otherwise, as I step through the issues that are past the bottom of the page, Jira scrolls down to that issue number... and I can no longer see the top (or eventually any) of the issue until I manually scroll back up.
Hi Jean
I currently see 50 issues at a time. Is there a way to display all issues at one time?
Yes you can by setting the following in jira-config.properties
jira.search.views.default.max = 100
However, this is not recommended at all. This will potentially cause performance problem of your JIRA instance you are currently running.
For more information on this, you can refer to this documentation: Limiting the number of issues returned from a search view such as an RSS feed
Hopefully it helps!
Cheers :)
You are always most welcome and if you find my answer is useful and helpful to you, please accept my answers :)
Hi Jean,
I've gotten around this by Viewing in Excel. The trick here is that there is a 1000 item max limit. You can temporarily get around this:
In "View" right click the Excel option, then copy the URL.
Paste the url into your browser window and edit the variable "?tempMax=1000"
For example:
Could be changed to
Then you can use Exel's search functions to sort through your data.
I'm sure there are more sophisticated ways, but that's what I've done in a pinch.
Just be aware that the limit is there for a reason - this puts a heavy load on Jira and going over the limit can really damage your performance while it runs.
Several, but I sense a deeper requirement here, could you expand on what you're looking for?
By the way - the "several" means that you define a filter to find your issues, then look at it in issue navigator - there are several different "views" with different output formats. But I ask for more information because I suspect you've tried them and not found something close to what you actually need.
Thanks for your explanation. I currently see 50 issues at a time. Is there a way to display all issues at one time? Sometimes it's helpful to see everything, for example, when you want to do a search using your browser's search function.
Not really - if you're trying to get thousands of issues, then you'll be putting unnecessary load on the system and generally searches returning more than a handful of issues aren't actually useful to us humans (it's too much to process).
The "xml" view would include everything, if your browser renders it internally, but it's horrid to read.
It would probably be faster and safer to refine your search.
