Hello Jan:
In this question you will find an asnwer on how to get a comment from an Issue Object. Afterwards you can iterate to find the latest one, or find the one with the latest date.
If this doesn't work for you, let us know and I'll program a 1 on 1 meeting with you to get it working.
Cheers!
Put below code under custom "scripted field"
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.comments.Comment
import com.atlassian.jira.issue.comments.CommentManager
def commentManager = ComponentAccessor.getCommentManager()
def comment = commentManager.getLastComment (issue)
comment.body
Hi Tukaram,
is it possible to add user name who commented on this along with comment?.
Yes , use below code
comment.body + " Author: " + comment.authorFullName
Thank you, Tukaram.
First of all thank you, however how can I add error handling on it? when an issue is created the field starts throwing up a lot of error messages in the logs as there is no comment yet.
Try below one
if(comment != null)
I can't see a scripted field option? How do I make this work with a Script Listener to populate a custom field I made called: "Last Comment"
this worked great for me. is there a way to break up the "+ comment.authorFullName" to just show first name instead of 'last,first' ?
Just want to see is there way to show the last comment without any inline images in the comment body? Thanks.
Is it possible to have this script only show the last comment of the reporter or the assignee ?
Small update
Replace
with
import com.atlassian.jira.ComponentAccessor
comment.body
Hi, Any idea if and how can I re-render the wiki style render ?
Lots of comments contain formatting and user mentions , new lines, bullets are not formatted at all.
Try this, it works but i found that my Database usage spiked after using it.
https://community.atlassian.com/t5/Jira-questions/Scripted-Field-to-copy-latest-comment/qaq-p/51850
