Displaying a custom field
joshO
Hello Everyone,
I have a customfield that is not on any screens but I change the value through the workflow using post functions. I want the value to be displayed on the Issue View but after the value is changed it remaines none visable. I know the value is being changed because if I do a search I retrieve the correct results. Does anybody know how to make a custom field visable if it is not on any screen?
Thank you
Udo Brand
February 3, 2013
You need to add it on the View screen, as soon as a value is set due to your transition it is shown on that screen.
If this field should only be filled by the workflow make sure you have a create and edit screen without that field.
Udo Brand
February 3, 2013
You need to define different screens for issue operations like create, edit and view. See here
joshO
I guess Im missing a connection here. how do you add a screen to an issue if it is not during a transition like create or during closing. so far I dont have any screens that are not displayed to the user.
Thomas Schlegel
Hi Joshua,
you can add your custom field to any screen you like, for more information look here
Cheers
Thomas
Register now
